CRX HF vyhrala zavod v spotrebe
Napsal: 08 úno 2012 23:31
Bolo to davneho roku 2009, ale aj tak:
http://ecomodder.com/blog/20-yearold-modified-honda-crx-hf-scores-118-mpg-fuel-economy-run/
CRX HF vyhrala zavod v spotrebe v state New York˙(USA). Najazdila neuveritelnych 118 mpg, to je 2,4 l/100km !!!
2. miesto: Geo metro (Suzuki Swift)
3. miesto: VW Jetta TDI
General maintenance before the fuel economy rally included:
■ I had the AC fixed, I hate hot and muggy.
■Redline MTL in the tranny and Mobil1 0w20 in the engine.
■new Honda airfilter, cap, rotor, wires. They all needed replacing anyway.
Modifications before the rally included:
■ Tires: low rolling resistance 155/65/14 Nokian HakkaR snow tires, brand new for the event, pumped up to 50psi mounted on Honda 14×5 alloy wheels
■Shocks: Konisport, revalved with SPSS1 valving, double adjustable, shortened body, set to soft
■Springs: Ground Control coilovers with 350 front 250 rear springs.
■Lowered car 2 inches, front camber at -3.5, toe set to zero front and rear, zero thrust angle
■Front wind deflector and rear wheel skirts made from thin polycarbonate, aluminum duct tape, self tapping screws and 3/4″ aluminum band
■masking tape to cover all panel gaps / seams, passenger door handle (forgot to do the driver side door handle)
■removed passenger side mirror
■I added lightness by removing the passenger seat, spare tire and tools, floor mats
■6 pound race battery.
A jak to dělaš ???
Jaky maš ty ??
